Pressure relief, need sound
I have an application that requires a 10,000 psi pressure relief..Is there anyway,(without electronics), that when the system reaches the 10,000 psi, that there could be a very noticable sound when it kicks off?
Basically its a hydraulic press, and I would like to know by sound when i am finished instead of a gage...
I have the pressure relief with a ball and a spring that I adjusted to 10,000 psi..How can you make it so it makes a distinct sound?
thank,s
Brents
RE: Pressure relief, need sound
Sounds like a perfect application for a "pressure switch" tied to an alarm or horn.  I have never used one for 10,000 psi, but Google it and see what you get.
Good luck,
Latexman
I appreciate the response latexman, but I am really looking for a mechanical noise without any electrical whatsoever..
Maybe this is an impossible task..I have been staying awake at night trying to figure something out here...
thanks latexman,
brent
I know on fire water lines there is ai in-line mechanical spinner that turns when water flows and it is connected to a bell clanger.  That's low pressure and high flow AND it's water.  I don't recall seeing anything like what you want.
Good luck,
Latexman
How about a relief valve with an external stem.  The stem would move a lever that clanged a bell.  My engineering concern is your 10,000psi value.  The hydraulic fluid is going somewher when it is relieved??   What action does the valve perform.  A gating function to an accumulator?
Good luck,
Bill
Bill Swain
Ultra Electronics Precison Air Systems
Technical Coordination Manager-US Programs
swainw@asme.org
Bill,
The 10,000 psi when relieved, will channel the oil back into a rubber bladder..this is a self-contained hydraulic unit..I can't have any external widgets that provide sound.
I was hoping there were a way to internally make a distinct sound..I am still clueless..
thanks,
brent
Too many system's information left out for a proper design.  I don't think this forum could give you the answer.  Seems like a system's engineering approach is required.
Good Luck,
Bill
Bill Swain
Technical Manager-USA
swainw@asme.org
