Hole table - not all holes show up
I made a hole table for a sheetmetal part. Most holes show up in the table, but some do not. All the holes are true holes and are not sheetmetal cuts. I can put in an axis table and all the axis show up, but that is way too much information. What could possibly be wrong. WF2- M120. Thanks in advance.
RE: Hole table - not all holes show up
I found the answer to my question. The holes were in a sheetmetal part, but all were not picked up, because they were on different surfaces. I had to redefine the missing holes so they were on the same side of the flattened sheet. In this case the green side which the coordinite system had been defined to.
