Problem with low pessuer air compressor
I am on a six month deployment for the navy, and we are asking for help with one of our lpac's it is a (if my E-7 is right) a nexie 100 built by ricks. It is a screw type comperssor that has an injection water type seat to it. It uses a cyclone type seperator, and a air dehydrator later on down the line. We are getting a constant high dew point fault, and all we can do for now is drain it down, and run it until the fault comes back. We are wondering how to stop this fault.
RE: Problem with low pessuer air compressor
However, some problems are common to most screw or vane compressors. A few questions.
Where is the "fault" analysis determined, at the seperator or at the service air outlet?
If at the service outlet, check the dryer operation (refrigerated dryer, I assume, and not an aftercooler).
Does the unit have a receiver or, if so, is it large enough?
Does the receiver have a functioning auto drain?
Has the seperator been serviced, lubricant and filter changed on schedule?
Is the unit set for 'constant run' or 'intermittant' (off and on on demand)?
If 'intermittant', does the unit have an 'auto drain' at the seperator and is it in functioning condition?
I've been away for several years, but perhaps I'll remember something useful...then again!
Rod
I will find out all of that info for you. For now I doknow that the unit does have a large enough reciever, and it runs in an intermittant mode sort of. It runs loaded, and unloaded. It unloads at 125 psi, and loads at 115 psi. I believe the auto drain is on the reciever, and the seperator. The seperator is a cyclonic unit with no moving parts, however the refrigerated dryer may be a little out of service. The people that work on it are not exactly AC and R techs, and I am not sure if anyone knows exactly how to adjust, or calibrate that particular unit. Like I said I will find out all the info that you requested,and get back to you.
