benchmark for solid bar with traverse hole
Has anyone seen benchmarks for a solid square or round bar in torsion with a traverse hole.
According to "Peterson's stress factors" book the max stress should be inside the hole.  In my FEA analysis it is on the outside.
Thanks in advance
EngForm78
RE: benchmark for solid bar with traverse hole
Are you comparing VON MISES stress to tension stress? or is it apples for apples?
EngForm78,
My reply is a little late, but I have done this analysis a number of times. The high stresses show up inside the holes as indicated by Peterson.
Gurmeet
