harmonics noise advisement
Need to see if someone can suggest a person or organization that can take a look at charting from hioki power analyzer that may make suggestions as to a solution for problem. DC plating process is interfering with upstream AC equipment.
RE: harmonics noise advisement
Usually, harmonics do not cause much trouble - unless you have PF capacitors than can resonance with the harmonics. I can have a look at the recordings. Try to isolate address from this: "edmatgkeorg". A dot is needed before org. The rest is a no-brainer.
Gunnar Englund
www.gke.org
Thanks for your response, I should have readings by Wed. evening and will send to you then. I will explain situation more in detail at that time.
Vetlover
I have sent drawings-Thursday afternoon. Thanks for your view. Vetlover
