Newbie Question - Max X, Y, or Z value of a curve
I have complex spline.  In my WCS plane, is it possible to get the furthest X point value of this spline.  I know this can be done in Catia, but uncertain how to accomplish this in UG.
Joe
Version NX2
RE: Newbie Question - Max X, Y, or Z value of a curve
I'd suggest this:
go to Tools->Expressions, then add a "geometric expression"->distance->first entity - point - endpoint-> pick the endpoint of your spline at Xmax; second entity - datum plane-> pick the datum plane normal to X.
This measure is a feature: you then can find it both in the Part Navigator and in the Expressions list as a parameter.
I don't know if this can apply for you...
Claudio
Try analysis distance pic the plane subfunction Y-Z plane (which means it is flat to the x plane)and the pic the spline. I think it gives you two a max and a min distance to the plane. Let me know if it works.
Thanks for the help.  Measuring to the plane does give me the minimum point.  I didn't see the max value, but I can always create a plane on the opposite side of material.
Another plane seems to be the simplist way to get max values.  Maybe one day they will give it to us in addition to the min value for info -> distance.  Send in those product enhancement requests!
You can get min and max values with one plane by using deviation analysis.
Ah ah, these are interesting straightforward methods!
But if I wanted to link somethig other to this measure, would then it be necessary to use the "expression->geometric expression->distance" method, or is there anyway something simpler in order for this measure to "stay" in memory and be re-used by some feature?
