Survey: Fema 273 - pushover analysis, anyone implemented?
Has anyone of pals here implemented the static nonlinear procedure(SNP), also known as Static pushover analysis recommended among methods of analysis for seismic behavior in FEMA 273?
If yes, please share your experience with us. Is it for design offices or for research. I fail to draw the line.
Thanx in advance
IJR
Thanx in advance
IJR
RE: Survey: Fema 273 - pushover analysis, anyone implemented?
I will say that this is a step in the right direction after so many years of oversimplifying structural behavior with the application of equivalent static loads. But, alas, even the ESL has its place in analysis/design.
Cheers.
