vacuum pump sizing
vacuum pump sizing
Ill be pulling a vacuum on a 240 ton self contained chiller, it has two circuts. My rule of thumb in the past has been 1 cfm per 7 tons of cooling. Looking at the physical size of the expansion valves this could be a 1/3-2/3 set up.IF my rule of thumb is correct, two 10 cfm pumps should be big enough for one circut, but if I use two pumps of equal size will they pull the vacuum oil out of each other and into my refrigeration system.
RE: vacuum pump sizing
