Sketches
Sketches
Sketches
Good Afternoon
Is there any way to save just sketches, like you can save features in
the design library.  There are some sketches that I use for both
extrudes and sweeps and I would like to be able to save just the
sketch.
Any suggestions?
Chris
RE: Sketches
You can paste it into a new part and save the sketch by saving the new part (only a single sketch in the part).
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
RE: Sketches
Library Feature is also an option.
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
RE: Sketches
How do I add just a sketch to a library feature?
RE: Sketches
Same way you add a feature ... just select it & do a Save as > sldlfp
RE: Sketches
OK, Thanks
Chris
RE: Sketches
When I first started with SW, I created a part similar to what Theophilus suggested, but with multiple sketches of often used shapes. Each sketch was named per the shape ... Star, Cross, etc, then when a particular shape was needed, I simply opened the part, then "drag-n-dropped" the sketch needed. Each sketch was fully dimensioned but not located (from the origin) so that it could easily be resized & located where needed in the new sketch.
RE: Sketches
IN SW 2006 you will see new functionality called sketch blocks.  It will be the best solution to your answer.  You will love them.
RE: Sketches
You can also record a macro, create the sketch, and save the macro. When you start a new sketch, play the macro.
Yanceman.
