sheetmetal corrugation Akesson had similar question
I am looking to form a corrugated sheet on top of the adjacent sheet. The last 1" of each sheet overlaps the next and deforms around it.
Akesson I searched and found you had a similar question a few years ago. Have you found a good solution? I have tried to place a user flange on the end of the sheet to make the bends up .040" but it will not do it if there is a corrugation in the sheet. The bends going over a curve the opposite direction give it some problems I think.
Any ideas?
Any ideas?
