ST 42 welded steel Tube in coil form D:14x2 mm.
I am searching for a supplier that can supply ST42 grade welded tube D:14x2 mm in coil form.
I will use this tube in a continious system bending machine so it is important to supply the material in coil form.
I would appreciate any help on the issue.
Regards.
Ertunc NESE
RE: ST 42 welded steel Tube in coil form D:14x2 mm.
Here is one source of metric tubing.  I would give them a call and see what they can offer. They are the distributers for 2 or 3 piping supply centers.
http://www.metricmetal.com/rn2393.htm
