Slot utility symbol
Slot utility symbol
How do you create a utility symbol for a slot? The standard linear centerline creates one longitudinal centreline and two latitudinal centerlines at the centres of the arcs.We are draughting to ANSI Y14.5M and I need one latitudinal centerline to locate the slot.
RE: Slot utility symbol
You use Cylindrical Centreline, have the filter set to Control Point, then dig near the mid-points of the straight sides of the slot. This will then give you a latitudinal centreline across the slot.
Thanks ewh & rghay for your comments.
