Stainless steel battery contact to Hasal finish pcb
I curently have a sub assembley that uses a stainless steel battery contact which makes a kiss connection with a pab on a hasal finish pcb. After a period of 3 to 4 weeks there is evidence of corosion of the pad which is causing the unit not to power up.
My questions are
(1) Has any one ever used stainless steel as a battery contact.?
(2) Is hasal a suitible finish for a fixed kiss connection
for a battery contact. ( 4.5 volts)
(3) if i changed the battery contacts to nicol plated stainless steel and touched up the hasal with solder would this be a plausable rework?
RE: Stainless steel battery contact to Hasal finish pcb
In your case, you may want to get these PCB contacts gold-plated. It can be a pain, but it can be done, using the kits made to repair goldfingers.
How many amps go through the contacts?
