How to put surface stress as load
Hi everybody
i have a problem for which i need some help
I want to study the effect of surface stress on a cantilever surface and resulting deflection but i am unable to find a load option for surface stress.
Can anybody help me in this regard
RE: How to put surface stress as load
More information is the place you need to start.
+ Elements used?
+ BCs
+ What have you tried already?
+ By surface stress you mean pressure? Or what?
+ etc.
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
Hi
Drez
thanks for considering my problem
I have used solid 92
It is not the pressure i am looking at.
It is the surface stress like the one that develops on a beam surface when it is deflected.
I want to put surface stress on beam surface and then look at deflection it cause.
if you could suggest a element for beams on which i can apply input as surface stress that will be great
Surface stress is an OUTPUT, not an INPUT. You have to apply a deflection/force/stress to obtain surface stresses in a beam in the manner that you've suggested.
Manvin,
Drej is 100% right. You can rely on linearity of your problem (if you are in linear case, as it seems) in order to compare the "trial" stress solution you get with your "trial" displacement/force/pressure with the "target" stress solution you want to compare with: simply, if trial stress is half the target, the load pattern that will give the target stress is twice the trial one. Of course due to calculation deviations, it's unlikely that you will get a stress pattern 100% compatible with your target one in every point: so, interpolate btw points to compare the stress patterns. Creating the "trial" load pattern requires knowing "how" the beam was loaded to obtain the stress pattern you want to re-create.
Claudio
Use initial stresses to stress your model . you can read in initial stresses from a file.See documentation for details of command and an example problem.
--BRC--
