Installation failure?
Hi guys,
I am a fresh man here. Just a question about the installation of ABAQUS_V6.5-1.
I've been expericed this error msg when I try to start the program:
FXGLContextEx::create<>:wglCreateContext<>failed
ABAQUS Error:ABAQUS/CAE Kernel exited with an error
I hope you guys can help out.
Lu
RE: Installation failure?
Did you check the Abaqus installation verify.log file in the installation_info sub directory? This tells you if the install was done correctly or not.
Other wise contact the Abaqus help deck (or should I say Dassault Systemes?)
