Arkansas Building Code
Please forgive the simple-minded question, but can someone please help me locate the web site for the State of Arkansas Building Code?
What I have determined so far is that Arkansas is following the 2000 IBC with additional "2002 State Amendments".  These amendments also appear to go by the name of "2002 Arkansas Fire Prevention Code, Volumes I, II, and III"
Searching through the official state laws web site, I found reference to seismic zones, but this was part of a law enacted in 1999 ("12-80-103  Seismic zones established"), and makes reference to the "Standard Building Code".  I can't see what it would have to do with 2000 IBC.
I can not seem to find a source for the actual code amendments themselves.
Any help would be appreciated.
RE: Arkansas Building Code
Normally Building Codes are adopted at the municipality level.  For instance, Little Rock has adopted IBC 2000 (http://www.accesslittlerock.org/departments/planning_development_bldgcode_p6.html#Code).  Unless you're doing work in an unincorporated area in a county without an adopted code, you probably don't have to worry about the State code.
From what you said, I suspect that there aren't any state amendments.  This isn't that unusual.
As far as the Standard Building code, it's the code that used to be used in the Southern states.  It's pretty much been replaced by IBC.
Maybe someone who actually does work in Arkansas can help you.
