Assembly mates ??
Assembly mates ??
I've only been using SW for a few weeks. I didn't know if it's normal in solidworks that when you change a mate in SW that thirty to fourty mate show up, and when I mated it the first time there were only three mates. Is there a way to make SW just show only three mates that define that part, because I don't need to see the other twenty-seven mates.
Printed Circuit Board Designer
Salt Lake City, Utah
Stangs rule!
RE: Assembly mates ??
View mates and Dependencies
This will list them under the part, however you cannot just list only 3 mates for that file. It will list all mates associated to that file.
You can place mates into a Folder that away you can have those there on the fly.
Highlight Mates, RMB, Select "Add Folder" and it will place them into a folder.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Are you running SW 2005, and a SP 1.1? I had that problem with SP 1.1, but haven't had that problem since upgrading to the latest SP.
Flores
If you are seeing ones which aren't related, then you definitely have a problem.
Can you post an image of your Feature Manager, expanded to show all the mates. (FAQ559-1100)
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
Jeff
I once knew a woman who drove me to drink and I never had the decency to thank her... W.C. Fields
Just like yanceman said, you can select two parts and the mates between them will show up as bold here.
