Physical properites of polysulfone
I would like to know the properties of polysulfone. I was able to get a few on the properties on the web. I am looking for the viscosity values. If there are different types of polysulfones, then some typical values would help.
Thanks in advance.
RE: Physical properites of polysulfone
You will have to contact the manufacturer of the resin as there are different formulations available. The link shows one manufacturers selection of 6 different viscosities of resin.
http://www.gharda.com/polymers/products.html#gafone3200
Thanks BillPSU. I'll check them and see if they can give me some numbers.
