error msg in abaqus---please help
Hi all,
I am getting this error in ABAQUS when I include a load input file in the original input file.
***ERROR: A CONCENTRATED LOAD HAS BEEN SPECIFIED ON NODE 0 . THIS NODE IS NOT ACTIVE IN THE MODEL
I dont have a node 0 in my model and I checked my load input file completely and i am sure that I didnot specify any concentrated load accidentally on node 0. Is there any other possible cause for this,
PLEASE HELP,
Maddy.
PLEASE HELP,
Maddy.
RE: error msg in abaqus---please help
*CLOAD
, 2 , 5000.0
in other words, have you got a comma as the first non-blank in a line somewhere in CLOAD? This would be taken to be node zero.
MRG
http://www.analysis.demon.co.uk
I have checked even that. i.e syntax of cload. Then again I started from scrach and this time got a error msg saying that a concentrated load is specified on node 7 which is not active in the model. I noticed that node 7 overlapped with node 123. So i have replaced my node 7 with 123 in load file and then it worked.
May be this was the cause with the previous one too..some nodes might have been overlapped and abaqus could not recognise!!!
