3D annotation font size
Yeah, this one is sort of trivial, but it is bothering me.
I am attaching text annotations to 3D entities in V5 in order to keep track of them.
But the size of the text is teensy, and I can't find a way to change the default text size.
Anybody?  Thanks for all the past help on my other inquiries.
RE: 3D annotation font size
3d annotations default are defined in the standard file you are using. your 3D annotations is ISO or ANSI or XYZ.. check this XML file.
Check online doc about drawing standards.
Check Tools/ Options / Mechanical Design / Functional Tolerancing & Annotation // Tolerancing / Default standard at creation (ANSI, ISO, XYZ...) it will tell you which standard file you are using.
Eric N.
