Go back to Wildfire colors from pre-Wildfire?
Can you go back to the Wildfire colors after you switch to pro-Wildfire colors? I can go to View - change screen/entity colors to pre-Wildfire (blue background), but sometimes I would like to switch back to Wildfire colors (beige background). Can this be easily done? I have WF2.
RE: Go back to Wildfire colors from pre-Wildfire?
Mark
Before switching to Pre-WF colours, save the scheme (File->Save in the System Colors dialog box). After you switch, try opening the scheme you saved. If it works, make a mapkey or two to let you swtich between the colour schemes.
Hope it helps
