has the exfiltration units changed in 7.1?
Hi.
Call my crazy, but wasn't exfiltration always modeled in ft/min?
The current exfiltration page is asking for in/hr.
The current HELP function associated with Exfiltration has a few examples of exfiltration rates, but those appear to be the old units of ft/min (could even be ft/hr - I'm real hazy on the old units.)
The current HELP page also has a "formula" to use in converting a Perc Rate (min/in) to V. The explanation of that formula mentions a factor of 12, but the example formula has a factor of 60 in it.
Obviously I can make the conversions as needed, I am just needed clarification on the units the exfiltration calculation is using.
Thanks in advance,
Craig Bailey
Thanks in advance,
Craig Bailey
___
Craig T. Bailey, PE
http:\\www.bailey-associates.com
RE: has the exfiltration units changed in 7.1?
I still think the units have changed though.
Possibly what is throwing me off is: .83 in/hr is listed for sand.
.83in/hr(1hr/60min)=0.0138 in/min
(0.0138in/min)^-1 = 72 min/in.
72 min/in for a sand is very slow.
NHDES (New Hampshire Department of Environmental Services) lists Group A sandy soil (Gloucester, Hinkley for example) as 2 min/in.
In central NH, If I take a sandy-loam perc rate of 10 min/in I get an exfiltration velociy of 6 in/hr (sorry to possible confuse the example.)
I realize NH is just one governmental body, does anyone have any other typical exfiltration rates they have used in the past? I suppose we'd have to key them to the Hydrologic Soil types, as the SCS "Soil Names" are variable region to region, and they are only valid in the U.S.A.
___
Craig T. Bailey, PE
Note: Previous project files will continue to produce the same exfiltration results. But the exfiltration rates are now entered and reported in inches/hour, as labeled.
Design values will vary widely. But remember that perc rate tests do not necessarily predict how a large pond will exfiltratate over many hours. The sample values listed in HydroCAD help are examples from several sources including http://se
