Edrawings Multiple Sheet problem !!!!
Hi to all,
I'm having a problem with producing an eDrawing with multiple sheets, it seems like only the active sheet keeps all the notes and leaders (annotations) and the other 2 sheets only have the drawings.  Is there a way to keep all the notes and leaders (annotations)on all sheets?
Colombo75
Colombo75
Sr. Industrial Designer
RE: Edrawings Multiple Sheet problem !!!!
Is your .slddrw file OK ... does it show the notes & leaders the way you want?
What are your system & SW specs?
Have you tried saving as PDF ... does it translate OK?
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
Hi guys,
Thanks for your suggestions, it seems that Sbaugh was right,  I needed to update to SP3, now it works great.
Thx
Colombo75
Colombo75
Try installing SP3 because I have no problems with notes or leaders on multiple sheets.  Whenever we installed SW SP3 it did not automatically install eDrawings SP3, so you may have to download it to install.
Flores
