Butteryfly Valve
Butteryfly Valve
Butteryfly Valve
I have a 4" Butterfly that leaks on a sch 80 pvc line for a aquarium on a salt water system. How can I replace it under pressure?
RE: Butteryfly Valve
Freeze the line to plug it and then replace the valve.  I have seen comcercial services that use liquid nitrogen to do this.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Freeze a PVC line?   Won't this present a high risk of cracking the PVC?
I would agree with mshimko - do NOT use a freeze plug on PVC material. Can you use a bladder or rubber plug on the inlet end of the piping?
