How can I test Bus Speed?
Is there a software where I can test a PCs Bus Speed?
Vic
RE: How can I test Bus Speed?
The file is a *.bin file.  How do I run it?
Vic
Forgive me, I gave you the wrong link. That file is for a Macintosh.
As for your question well Amidiag was recommended to me and it is supposed to test everything including all of the bus lines. It has a price tag on it though, however you can download a demo. How much functionality it has, well you'll have to tell me.
Find AmiDiag at
http://www.ami.com/AMIDiagSuite/
Hi Laffalot,
Thanks for your help, but the software doesn't run any tests regarding PCI Bus.  It does show information regarding the PCI thought.
Thanks again,
Vic
All hough this is not what you asked for given you previous threads (PCI BUS analyzer) I thought this may be helpful.
For info on the PCI and some PCI programs see
http://members.hyperlink.net.au/~chart/pci.htm#craig
However the programs don't test it they just tell you about all of the devices you have on your bus (from a dbase of 4000+) and what's more they're free !.
For software that test various buses (benchmark tests) and get information see:-
http://benchmarks.dacris.com/information.htm
http://2edc.com/products/infopro/index.html
http://www.hwinfo.com/
Like I said not exactly what you want but may be of some use.
Any help ?, yes no let me know.
I think SiSoft Sandra2000 does the job (among other tests).
you can test the demo (dl www.tucos.com)
Hi michalis,
The site you've posted does not work.  Is there another address where I can download the software?
Vic
I found a site to download SiSoft Sandra 2001 at:
http://www.5star.nsm.co.uk/Utilities/Diagnostics/sisoft-sandra.html
It gives me information about the PCI devices, but it does not test the PCI bus itself.
Thanks for the help though.
Laffalot,  I looked at the sites you recommended and downloaded the software, but it isn't quite what I'm looking for, but thank you for trying.
have you tried norton utilities?
No I haven't.  Does that software test the bus?
that software is supposed to be able to run various tests on your computer. i haven't tried the new version and therefore i can't have an opinion. you can download a trial version from www.symantec.com. I think it's fully working for 30 days or so.
you can also try various benchmark utilities from ziff-davis. try this url:
http://www.pcmag.com/category/0,2999,s%253D1477,00.asp
if it doesn't work go to PC magazine homepage:
 www.pcmag.com, and search for "benchmarks"
I hope i helped... :)
I found a website that will test everything from bandwidth to memory.. I have used it to determine which upgrades to do andhow my pc performs.. check it out
http://www.pcpitstop.com/default.asp
Good luck, Chad
Try http://www.h-oda.com ;   goto downloads and get the cpuid .exe, this is a tool for overclockers to monitor their overclocked CPU-mobo etc.
Cheerz :)
