3d Points input into Solid Edge
Hi
I'm using V17 Solid Edge, and i'd like to know if this is possible:
Can I get some 3D points in space and input them directly into 3D part. The way i'm doing it now is by extracting a parallel plane in one reference direction, then drawing a point in the other two reference directions.
This takes quite a while, so is there a simple way to say here's my x,y,z, give me a point in space.
Cheers in advance
Cheers in advance
RE: 3d Points input into Solid Edge
The only work-around I know is to create a curve by table (in the surfacing toolbar in Part or psm) and create a new spread sheet : enter the coordinates (3 columns X,Y and Z) for each point. Then, in the parameters choose the option 'linear segments'.
You will not have 3D points but you will have segments which will enable you to use these points (their extremities).
NB: you need at least 2 points to use this method
HTH
Fred
Not sure if there is anything new in V17, but in earlier versions you can create a co-ordinate system for each of the points you require.
Click the Co-ord system icon and use the Orient by Key-in option.
Enter your co-ordinates in the X,Y,Z boxes then click Next and then Preview.
This will orient the axes parallel to the file XYZ axes.
You can then use the lines and keypoints of the axes as reference for creating further geometry.
In the past I've used this method for creating the sweep path for flexibles such as hoses and cables.
Beachcomber.
PS. What's 17 like? Are there any apparent 'bugs' and have your older version files upgraded OK ?
As for V17, there aren't any bugs that really crop up at the moment. The files have converted ok, although it takes a little longer the first time you open them. Its all trying to be like UG now, with loads of menus at the top, pay for add-ons & licences etc.
hope this helps
cheers again
Any particular reason for doing so?
Any particular reason for doing what ??
ttaktn
beachcomber
Hope this clears things up.
regards
Also, sometimes, i have suspension co-ordinate points, and i'd like to put them into CAD for my rotation centres. Ideally, i'd have some way of creating points in space in the CAD system. This could be substituted for parts like rollcage intersection points.
Hope this helps in your understanding of the problem
Sorry if I appeared a bit dim, but I wasn't sure whether you were refering to ttaktn's original question or my comment about the hoses etc.
If 3D point input is missing in V17, maybe it should be an enhancement request for the next version, along with being able to create a 3D profile, similar to the tube path command but comprising lines and circular arcs/fillets if required.
How do ordinary users get these sort of requests to UGS ?
Beachcomber.
Ken
