Joining polymers
Joining polymers
Joining polymers
Can anyone suggest a way or a glue to join securelly PE with either PE or PTFE?
i dont want so spend too much money or waste very long time.
RE: Joining polymers
Use hotmelt glue gun to bond PE to PE, or melt the PE pieces together.  You're not likely to find a glue to bond PE to PTFE.
ChemE, M.E. EIT
"The only constant in life is change." -Bruce Lee
3M specialise in gluing plastics like PE and PTFE. They have some success. I never did a costing, but I don't think it will be cheap
Loctite has charts for what glue to use for what type of plastic. For polyolefins I've used their type 406 with a primer 770, and the bonding was very good. They are coming out now with a one-component glue called 3300.
Vassia:
You’ve selected probably the two hardest materials to adhere either to each other or themselves.  The only adhesive that I have found that works reasonably well is epoxy.  It it’s best to oxidize the surfaces to be bonded by coarse-sanding followed by flame-treating to oxidize the roughened polymer surface.
Rich Geoffroy
Polymer Services Group
polyserv@cox.net
