Temperature measurement with DMM
Looking to inexpensively monitor temperature variations without much concern for actual temperature. Ranges around 150C. Would a Thermopile with 500mA output connect directly to a DMM ? Or is there another way. Cold junction would be possible --Ice water or? As you can see Electrical not my fortee
RE: Temperature measurement with DMM
How inexpensively, how accurately?
If you have power available (2 or 3 volts), use a silicon temp. sensor chip (LM34, see National Semiconductor site, www.national.com).  Accuracy can get as good as +/-.5 deg. F.
Cheaper, but less accurate are thermistors - read them directly with an ohm meter; these are good to +/- 1 or 2 deg. C when calibrated, or used as differential sensors.
Cheapest: you can read a thermocouple directly in mV with a DMM, effectively measuring the temp. difference from the meter to the probe end.
There are some real cheapo DMMs fom south-east that can indicate temperature. Sometimes a thermocouple is included in the bargain.
Fluke, of course, have temperature probes that can be connected to any DMM. Not only theirs. They also have a non-contact surface temperature transducer.
Google +DMM +temperature for a long list.
If you want to experiment, you can always use a thermistor and a couple of resistors to have a limited linear range. http://www.aicl.com.tw/ntc04/application/application.htm shows a few examples.
Gunnar Englund
www.gke.org
Hi Davee3,
All the above suggestions are fine.. They just require a heck of a lot of mucking around and table look ups, with the exception of the National part.  Which all increase the chance of a screw up.  I have used all the above methods with various success.
Lay hands on a non-contact temperature measurer. One of those point-the-laser-spot-read-the-temp guns.
The temp gun sees the light of warm objects, so as you use it imagine everything giving off light that signifies it's temp, and use the gun appropriately.
I use mine to check the temperature of my aquarium, the chili I was cooking yesterday, room temperature, my oven temperature.  You can use them to find which cylinder is missfiring. The one with the 20F colder header pipe....
I use mine just about every day!  I use it on motors, vacuum pumps, refrigerators, IC's.  Just a whole lot of things.  You can measure spots that any other measurement method works poorly on. Surface temperature of a motor is a good example. If you want the temp of a motor that isn't instrumented internally the temp gun is great.
Here are a bunch under a hundred bucks.
http://www.techinstrument.com/acata...hemometers.html
http://www.toolsource.com/ost//prod...EGDTVL90HBJFFME
http://www.calright.com/_coreModule...uctMasterID=188
http://www.nottheusualstuff.com/cat...?products_id=50
If you just want a number to match against, use a cheap meter and a silicon diode like  1N4001.  Most low cost meters have a diode check position that puts enough voltage on the diode.
Anyone who wants to follow those links above:
http://www.techinstrument.com/acatalog/Infrared_Themometers.html
http://www.toolsource.com/ost//product.asp?brand_id=&sourceid=googleraytek&dept_id=500&pf_id=92165&mscssid=0LQ45AWH3ELU9HAPNEGDTVL90HBJFFME
http://www.calright.com/_coreModules/eShopping/productDetail.aspx?productMasterID=188
http://www.nottheusualstuff.com/catalog/product_info.php?products_id=50
itsmoked
When you copy someone's post from another board (http://www.clubhotrod.com/t13354.html) make sure you expand the links rather than copy&paste
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
Hi johnwm; Thanks, I never even noticed..How annoying!!
Thanks for hunting up the correct ones.
That took some sluicing to hunt that back to my original post.
...not really - a Google on 'non-contact temperature measurer' from your post and it's the first result  !
Good Luck
johnwm
