Why Am i have having trouble mirroring
Im creating a basic sketch of a parrallelogram, but everytime i try to mirror it over a centerline it aint working. I want to mirror it in the front plane.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Why Am i have having trouble mirroring
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
a to be mirrored all the way here a
with a centerline in between but it wont do it.
Remember:
You cannot mirror construction geometry (dashed line).
You shouldn't have elements crossing your centerline.
After you select all the sketch segments you want to mirror, CTRL-Select the centerline (dashed line, construction geometry) that you want as your center, then use the mirror function in the Sketch toolbar. It will work.
By definition, your centerline will always be centered between your mirrored geometry.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Can you post an image including the Feature Manager? See FAQ559-1100
Claudio
