Sulfuric Acid on the Web
To Sulfuric Acid professionals and novices,
The extensive information previously available from the site of "Sulfuric Acid on the Web", is again available at
www.sulphuric-acid.com (Note the British 'ph' in sulphur)
There is the Technical Manual with a wealth of data on acid plant design, materials, operations and maintenance, corrosion, and inspection.
If you see DKL at the Clearwater convention, please remember to thank him for assembling the website over the years, and congratulate him on this return to the internet.
