Toolbox drop file error
I am currently having problems with our shared toolbox installation. Whenever an assembly is built which contains a type of toolbox fastener (let's say a panhead machine screw), later when trying to add another panhead machine screw I get a "toolbox drop file error" and am not allowed to add the part. I can copy the one that I already placed in the assembly and then change the fastener size but this seems like a hassle. Another user here is seeing the same problem, but one other user seems to have no problem at all with this. To me this would tell me that the shared toolbox rights are correct, but that me and the one other user have some setting screwed-up. So far I haven't been able to find one. We are all running service pack 3.0. Thanks for any help.
RE: Toolbox drop file error
Or check each of your Toolbox (Pulldown menu) settings to see if they are the same as well.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.1
I copied my colleagues toolbox parts (the one with the most assemblies and toolbox configurations) onto the network and mapped the ini file to that. Ok....When I open his assy on my computer I get toolbox errors (toolbox still pointing to the C:/ drive) not finding his configurations. I talk with tech support and said I need to go to tools, options, file locations. reference documents and map to the toolbox folder on the network. Ok...now it opens correctly...what gives? Now I have an ini file and reference docs point to the same nework folder. Is that right?
Now that I filed the assy document, I return to refenece documents in the tools options area and delete the link, hit ok to save the changes and reopen the assy doc. Now it opens correctly (toolbox now points to the network folder S:/ drive).
Anyways...back to the thread...My assy will not allow me to drop a toolbox part into to my assy. It sez the parts already open and then crashes.
My ini file is correct and is mapped correctly.
I know the other users are going to have errors on there assy's, but it's the price you pay when things are done half a$@.
We're moving to PDMWorks in a couple of month's and these items need to be resolved.
Macduff
Colin Fitzpatrick
Sr. Mechanical Designer
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
SW2005 Office SP 3.1
Windows 2000 SP4.0
NIVIDA Quadro4 750 XGL
This problem happens because of file conversion from old version to new one. If you start a new assembly, you should not have any problem.
To work around this problem, you can do one of the followings:
1. Remove all instances of that particular toolbox part ("panhead machine screw" for an example) from your assembly document. Save and close the assembly document and reopen it. Now, you should be able to drop your toolbox part into your assembly
or
2. Just open your assembly with lightweight components. Go to "Tool" menu, select "Option", and then click "Performance". Check "Automatically load components lightweight" box. Now reopen your assembly. You should be able to drop your toolbox part into your assembly.
It is not an ideal solution, but it will help you before SW fixes the problem.
Alex
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Macduff
Colin Fitzpatrick
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
Windows 2000 SP4.0
The only thing I could think of in that case is that perhaps the SolidWorks install was installed into a non-standard directory (like I do) such as Program Files\SolidWorks2005 or something to that effect. If that is the installation type, then there is a partner directory of Program Files\Common Files\SolidWorks2005 Data that should include the "2005" in the directory name, just in case.
When you upgrade service packs, you need to remember to change the installation directories of both from their standard directories with no "2005" name so it matches your initial installation.
That's a long shot, but if you check your computers in which SW is installed--if you have both kinds of directories--you may need to reinstall recent service packs to get everything set right (since it was probably missed somewhere along the line).
Jeff Mowry
Checked the programs files and sez "Solidworks" and the common file area has "Solidworks Data". Seems that I'm ok. I'll hunt around to see if I can anything else out-of-the-ordinary.
Thanks for your help,
Macduff
Colin Fitzpatrick
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
Windows 2000 SP4.0
