Remove the sulfureted hydrogen -- Help!!!
Could any chemical engineers tell me whether there is a way to remove the sulfureted hydrogen(h2s) from the gas (H2 60%,CH4 30%,CO 9.6%, H2S 0.4% (v)) around normal pressure(106KPa(absolute))? If you know and can tell me something about it, I will be grateful!
Thank you!
RE: Remove the sulfureted hydrogen -- Help!!!
Your question is much to broard
There are noumerous ways to revome H2S from various types of "gas". The optimal solution depends a lot on your application. Is that H2S a contaminent in a synthesis gas?
Best Regards
Morten
