Tolerance display when using dim symbols
We are currently using Pro/E-2001
Occasionally we use symbols for dimensions in our drawings.
A question came to me about how to show the symbol and still retain the tolerance after the symbol.
It seems that when you change the dim to a symbol the tolerance info disappears. I told her one could append the tolerance to the symbol as text.
Perhaps there is a config setting that deals with this? Or can you put the tolerance in the table?
I recommended this site, so she may post this question also.
Thanks in advance
SrG
Thanks in advance
SrG
RE: Tolerance display when using dim symbols
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Do you trust your intuition or go with the flow?
