Hydraulic Fittings
Hydraulic Fittings
Hello all, I'm a relatively new engineer out of school and recently we ran into a problem with a hydraulic fitting. The male end is set in a bored hole in the machine so that the end of the fitting is flush with the outside surface of the machine. When the female end is connected to provide the hydraulic fluid, the pull release in also set into the machine and is really hard to get at. Boring out a bigger hole is not possible. What I was wondering is if the it is possible to buy a pull release fitting that is longer. The one we have right now is probably about 1/2 inch so if we could get one that is at least an inch long so that it is sticking out past the surface of the machine and easy to pull then that would be great! If anyone knows the answer and even better where to get one that would also be great!!!
Thanks all and happy engineering
J
J
RE: Hydraulic Fittings
Barry1961
J
Move the nipple outboard and add a protector around the nipple.
