two phase velocity
two phase velocity
Anyone out there familiar with API 14E? I am trying to evaluate the velocity of a two phase hydrocarbon flow. The API standard refers to a simple calculation v=183/(rhomix)^1/2.
Should that calculation be considered to be a mere guideline or what? How far can one deviate from it? 20%?
Any thoughts on the topic?
RE: two phase velocity
Vmax = C / (rho)^1/2
C is typically taken as a 100 by a lot of companies with short term excursions by some for intermittant operation. I haven't seen the 183 figure. For clean fluids you can push the 100 quite a bit.
There's also a rho*v^2 limit that some companies use that is simply another form of C/(rho)^1/2. I worked for one company that used the rho*v^2 limit for velocity in their flare system. I was doing some capacity testing and for some reason was curious how it compared to the 14E equation and found I got the same velocity with each (rho*v^2 worked out to a C of 370 I believe). With a little manipulation, it's easy to show they are the same equation expressed differently.
What are you trying to do? Back calculate the flowing velocity? This is not going to give it to you.
