how do I design a pulley system to lift a sample using a motor?
I want to make my own dip coater. A dipcoater is used to coat a sample by pulling it out of the liquid at a controlled rate. I am using a servo motor with a horizontal shaft. I cannot visualise how I will connect my sample to this motor so that it will raise and lower my sample into the liquid. Could you please help?
thank you
Veena
thank you
Veena
RE: how do I design a pulley system to lift a sample using a motor?
attach a hook to the chain, and arrange the sprockets and chain speed to pull the part at your desired rate.
this doesn't really require a servomotor, but you can use that to control speed and/or direction...
