Gas recirculation system in Nutsche filteration
I was trying to figure-out how the pressures (both in the filterate receiver & the Nutsche itself) are controlled during the various stages of a filteration when using a liquid-ring compressor for subj.. Anyone with experience in this operation ?
RE: Gas recirculation system in Nutsche filteration
we are typically at a few inches of water column on the discharge side and then at a vacuum on the suction of the liquid ring pump.
what pressure you run has a lot to do with what solvents you are drying or evaporating from the nutsche.
