How to make Aluminum and steel gears work together?
I am faced with a problem of using an aluminum pinion gear and a steel spur gear. This project is time sensative. In other words I have no time for Hard coating the aluminum gear.
Can anyone suggest how to prolong the life of the Aluminum gear.
These gears have a fair amount of torque on them and move at a relatively hi RPM. I can't give exact #'s to rpm and torque because I simply do not know.
As of now I can get somewhere around 12 minutes of use from the aluminum gear and need to extend life to 35 minutes at least.
I hope someone can give me some information to make this possible.
Thank you.
Thank you.
RE: How to make Aluminum and steel gears work together?
http:
It may seal the pores in the aluminum.
Why can't you tuff coat the pinions?
12 minutes even to 35 is really a short
life. Must be very expensive.
How high of an rpm? Relatively high means
nothing to anyone as it is a subjective
statement.
I have thought about the graphite lube, just have not tried it yet.
These gears are exposed to dust and dirt. They are not sealed inside any casing.
I can't tuff coat the pinions because I have to have everything done by this thursday, and I get my second batch of new gears on Wed. no time to have it done.
The RMP's are varied, at idel 10,000 at full throttle 33,000.
I plan on having the gears cut from steel in the future but for now time just doesn't allow me to do it.
Expensive? a little but not bad the aluminum gears are $4.75 a piece and I use 2 at a time. So I have 4 sets to use for the weekend of racing.
This is in a R/C application however don't be fooled into thinking that these gears don't see a lot of RPM and stress.
They are driven by a Nitromethane engine producing around 3.5 HP and pulling a 13.6 lbs vehicle. with on throttle jump landing, bumps etc. This drive train really takes a beating. We often break Titaninum turnbuckles, ball studs etc.
The final race will be 30 minutes long with a 5 minute warm up so 1 set of gears will have to last 35 minutes.
Once this material is applied to both gears still use a high EP Oil even though you want get much lubrication at your RPM.
http://w
