Code Case 2051
Code Case 2051
Code Case 2051
Hi folks,
I'm brand new here.  I work as the QA/QC Manager for an industrial construction company in Maine.  Life's hectic at times, but never dull.
One of our guys is working on a Section VIII pressure vessel that was constructed utilizing CC 2051.  I don't have access to it.
Does anyone know what CC2051 is about?  Any information would be greatly appreciated.
Thanks.  Charles
RE: Code Case 2051
Charles,
Go to ASME.org, hit the "Codes&Standards" tab and you should be able to run it down.
RLS
RE: Code Case 2051
Must be a very old Code case , because I went back to 1995 and it does not exist.
RE: Code Case 2051
It must be one that expired.  You can receive a copy for a nominal fee from the Linda Hall Library.   Their # is 800-662-1545.  The last time I purchased a copy of a Code Case it cost $16 and they emailed it within 24 hrs.  Cost may vary based on the number of pages in a particular Code Case.
RE: Code Case 2051
Thank you for all the replies.  I'll get ahold of the Linda Hall Library.
Charles.
