Metallic Sprayed Zinc Coating
I understand that Inside Paint System No. 7 (Metallic Sprayed Zinc Coating System) was removed from the current AWWA D102 (Painting Steel Water-Storage Tanks) Standard because the AWWA is developing a new standard for this and other similar coatings.
Does anyone know if this new standard is available, or when it might become available?
S. Bush
www.water-eg.com
RE: Metallic Sprayed Zinc Coating
I had understood that requirements for NSF approvals had really been a problem with galvanizing, and this may have been the motivation behind not including the system you mention. It was not often used, and cost seemed disproportionate to the benefit of it.
