CFRP Damping Ratio?
CFRP Damping Ratio?
CFRP Damping Ratio?
I am looking for the damping ratios for CFRP composites. The exact ratio is contingent on the orientation and type of fibers but I am just looking for a ballpark number for a quasi-isotropic layup. Any help?
RE: CFRP Damping Ratio?
Hi Sdpe,
I have used CFRP tubes for a space structure. For my analysis, I used (with fear since did not know what to expect) a Q of 25 (damping of 0.02) and this led me to conversative accelerations when I compared with the results from a sine test.
Best regards,
Franck
I've seen steel analyst use a damping ratio of 2%, so it doesn't suprise me that 2% would be conservative.  I've seen thick balsa cored (3 to 6 inch) composites with as high as 6%.  If I had to take a guess, assuming a carbon fiber of modulus 30e6 in an epoxy resin, I would say 3% would still be conservative.  4% may be close...but that's an educated guess (with a strong emphasis on GUESS.
Garland E. Borowski, PE
Try an internet search on "Material Damping of Vibration". When I did that some months ago I found that the majority of recent information involves damping of composite material.
