Drive in vector control mode
Hi all.
I want to run a ABB ACS550 inverter in vector control mode. I believe i have to set P9904=1. Can you tell what other critical parameters i have to change? And also does anyone know how the motor ID run works in ABB ACS550 ? Because it is somehow unclear in the manual.
Thank you very much.
RE: Drive in vector control mode
You will need to set the P gain and the I time but probably will not need to set D gain. These parameters determine how accurate and responsive the motor will be to speed and load changes.
Otherwise, the drive programs up much like any other drive.
