volumetric features
volumetric features
I have a couple questions about volumetric features if anyone can help.
What would you use a volumetric feature for?
Can't you do the the same in part design and more?
Is there an advantage to using volumetric features over part design?
Thanks in advance :)
forfun
forfun
RE: volumetric features
Lee
http://www.lmco.com
It will take a dumb solid and build a feature tree for it.
Lee
http://www.lmco.com
Just like before when you had a JOIN in GSD, you 'convert' Volume feature in Solid with Close Surface from Surface Based Feature toolbar in PartDesign.
Eric N.
The only reason I can come up with is someone must have requested it. Maybe they doesn't use Product Design (solids) and work only with surface models? Or they want to be able to convert their V4 volumes into V5 and be able to work with them?
