Fanuc CPU problems
Fanuc CPU problems
I have a problem with a RJ2 robot controller. The teach pendant is continually freezing however is ok if the robot power is cycled. The only fault indication i have is via the LED indication on the CPU. This points to bad parity on the RAM. I am reluctant to change the CPU though due to not having a very recent back-up. Can anyone offer any advice
RE: Fanuc CPU problems
