Weld Inspection IAW AWS D1.1
Does the AWS D1.1 code require that fillet welds on welded structures such as gussets in I beams have the ends completetly wraped? Or, does the code allow the ends to be left unwelded?
RE: Weld Inspection IAW AWS D1.1
Chapter 2 has all sorts of limitations on the connection configuration but there's no across-the-board ban on just welding the sides.  Your particular case may or may not be okay.  See Figs. 2.5 & 2.6.
Hg
Eng-Tips guidelines:  FAQ731-376
