Conditional Formatting problem
Is the following possible without using VB or macros?
Suppose cell B1 has conditional formatting, such as Cell Value  is not equal to cell A1. Now, I need to copy and paste B1 every 10th row, numerous times, down the spreadsheet.
What results, such as in cell B11, the conditional formatting copies as Cell Value is "not equal" to cell A1.
However, I need it to be "not equal" to cell A11 (every value in the A column, A1, A11, A21 will differ).
RE: Conditional Formatting problem
If you look at your conditional formatting dialog box for some reason the cell address gets set to absolute (ie $A$1). Just get rid of the dollar signs before you copy it and Roberta's your aunt.
Cheers
Greg Locock
Greg,
The cell address was actually set (unknown to me) as "A1", not  $A$1.
(I have no idea what the significance of the quote marks is)
I then removed the quote marks, and as you already knew, problem solved easily.
thanks!!!
The quote marks meant that the A1 was treated as text rather than a formula/cell address.
Ken
Thanks Ken, that is useful information.
