Fluid Flow - Water Blowdown
Can I calculate an actual flushing flow rate with a trend peak shape from an OS?
Assuming the peak as a triangle and measuring the duration in minutes between distance and top, then multiplying base line and peak to find a volumetric flow rate – g.p.m.
I’m trying to capture the flow during a process sequence.
Bucs
