Two piece gear designs
Where can I find data regarding durability data for two piece gear designs with impact/shock loading?
RE: Two piece gear designs
etc.
1)Split in half across a diameter to produce two half gears which are somehow fastened back together in the style used for example on large kiln drives?
or
2)Split through the apex of a double helical?
They are both spur gears.
when cut and then their relationship
ensured by pinning, then you could treat the
gear assembly as one gear. If not, you would
have to derate it by the obviously mismatch
that would occur during the mesh cycle.
If you lined up the high points of each gear
it would be of some help. I assume the gears
will be bolted together and have locating
pins around the bolt circle. Just curious
why the gears were split if it is like
case 2 as carburize suggests and not 2 half
circles.
