Data level reduction
I am currently modelling in R14 and have been asked to drop the data level back to R13, can this only be done through the utility or is there a simpler less laborious route?
RE: Data level reduction
The utility is the only way I know, unless you want to do it with another format such as IGES or STEP but you need licenses for that. And the result at the end will be about the same.
Eric N.
Its the only way (with the utility) and you can do that also in a batch mode for a lot of parts.
Fernando
Thansk guys, though tthat would be the case, they just could not make it as simple as a save option could they.....
Oh well, thanks for all your input.
