SW tries to install DAO
Hello guys,
I have installed SW2005 Pro SP3 on my computer: P4 2.6GHz Windows XP SP2.
When I open a new SW session and click on Hole Wizard icon, SW tries to install DAO. I have to click Cancel several times before using Hole Wizard.
Please let me know what is DAO and how can I fix this problem.
RE: SW tries to install DAO
DAO probably refers to Data Access Object, but why it's doing that I don't know.
What is the exact message you get?
Have you tried allowing it to install the DAO?
Have you tried a repair or clean re-install?
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
1. Do a repair install.
2. If 1. doesn't fix it, use Rx to capture the problem and send it in to SW.
Some other suggestions if a repair install doesn't work:
Hole Wizard requires Toolbox, so make sure you have that selected under "Add-Ins."  The last time I used DAO was for system-generated e-mails, so look under options and see if you're sending performance e-mails.
DAO is a Windows component.  What version of Windows are you running?  Perhaps if you get your OS up to the latest and greatest SP, the problem will go away.
I could be the world's greatest underachiever, if I could just learn to apply myself.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
It is somehow related to Toolbox. The error message I am getting is: The feature you are trying to use is on a network resource that is unavailable.
A repair install did not fix the problem.
Did you then Rx the problem and send it in to SW?
